Discuss Trace wire through my house in the Electrical Tools and Products area at ElectriciansForums.net
Rodrayner
Hi,
I am removing my room thermostats as i'm going "smart heating" and need to trace the wire from the room stat downstairs back to the heating control in a cupboard upstairs so it can be removed from the circuit.
I'm thinking all i need is a simple tone generator / wire tracer like the ones used on network cabling but i'm not sure if they would work or be sufficient.
The power will be switch off when i trace the cable as all i need to do is identify which wires are which.
Do i need anything special or can i just buy something simple of amazon with a couple of crocodile clips and a 9volt battery?
Thanks in advance.
Hi,
Thanks in advance.
An electrician would be able to identify which cable it is in the wiring centre by what it’s connected to. For example if it was an S-plan the switch live of the cable in question would be connected to the brown of the CH 2 port valve and if it was a Y-plan then the switch live of the cable in question would be connected to the white of the mid position valve.
head bone connected to the back bone, backbone connected to the thigh bone, thigh bone connected to the knee bone, knee bone connected to the ankle bone. ankle bone connected to the foot bone, foot bone connected to the steel toecaps, praise the name of H&S.
Fair enough... my mistake... i apologise... i didn't realise this was a forum for just trades people to speak to trades people... i made the mistake of misunderstanding the DIY section as actually asking people for assitance... if i knew i was just going to get advice telling me an electrician would know how to do it i would of asked my mum..
Are you incapable of checking to see what heating system you have, as in a S,Y,C plan etc? And then following the advice I gave you in my other post? If so you shouldn’t be trying to undertake this task in the 1st place. I would also drop the adolescent teenager attitude if you wish to receive more constructive advice from this forum. Thanks Lee
If you want to remove the Stat cable completely, just start at the stat and follow the cable and remove it as you go, with the power off. You will have the answer to where it's connected when you get to the end. If you're removing the wired Stat and fitting smart then you'll need to understand the wiring in the Junction box/wiring centre when you connect up the hub or receiver or whatever is on the wired end of the system.
@Leesparkykent, thanks for the feedback but i'd prefer an answer to my question rather than an "electrician would know how to do it"... i dont need to know what or how the cable works... i just want to remove it... in its entirety.
But if you just simply remove the cable your heating will stop working. You need to know how to incorporate the new controls to replace the existing stat so you will need to identify the connections at the wiring centre anyway.
I was going to report you to a moderator, but then you are a moderator :)
OP: For tracing cables, using a battery, croc clips and bulb, or whatever (a multimeter would suffice) then you would have to disconnect the joints in the wiring centre. These wiring centres can be complicated to understand for a basic electrician, never mind a layman DIYer.
The smart stat wiring diagram may appear simple, its only 2 wires, right? but there is so much can go wrong... and I bet the instruction say "if in doubt, consult a qualified electrician"
Lee was right in his response, and as he is a moderator, he doesn't dish out advice like "get an electrician in" willy-nilly
would've, would've been fine too...
but I am being Pedantic Pirate, and really should of...sorry, should've gone to bed ages ago
You don't need to "trace" the cable as the thermostat cable should be identifiable on the schematic for the boiler and controls.
Oh and just ignore the cantankerous old fogeys posting up rubbish.
Thermostat(s) as in several?
Do you have individual thermostats for each room/area?
If so it is too complicated to give practical advice here, you really do need to contact an electrician.
Reply to Trace wire through my house in the Electrical Tools and Products area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
