L
leolec
Got a call out yesterday to look into a problem which has stumped me, and it seems many others before me.
Wylex 16th ed Box (installed 2005 by qualified registered spark who left good cert), 2 lighting, and door bell on main breaker together with a Hager bell transformer, shower sockets immersion, etc on 100a 30ma RCD.
When kitchen 18" fluorescent is switched "off", it regularly trips the RCD which obviously its not attached to.
The owner worries that on leaving the house and turning off the light the RCD will trip and the freezer will defrost during the day.
The lights switch is below a shower cubical, there is a socket on the opposite side of the door frame at light switch height, I've done an insulation test on the plaster work above the light switch say about 3 foot above and get 190meg and above the socket and get similar.
I started thinking about back EMF but can't figure out how anything from the fluorescent call leak across to the neutral of socket or shower or immersion circuit especially given that the RCD never goes when everything is on or if a bulb blows.
I measured trip times and the RCD seemed to react OK but don't have a ramp tester so I only suspect the RCD is OK
The only thing I can come up with is to put a bayonet fitting in the kitchen to try and move towards proving leakage out of the flurry (which others have replaced twice)
Any suggestions thoughts would be very welcome
