So each light only has one switch that operates it but both those switches are on the same switch plate.
If that's the case there shouldn't need to be any connection between switches. BUT its possible the live from the first light is being bridged across into the second switch to then be switched to the second light.
That avoids a live feed needing to come from the second light. But that's not normal as you need a wire to feed the switched live to the second light so you may as well send the live down one core of that wire and the switch live down the other. You'd need to look at the second lights fitting to see the bigger picture.
Pat, yes both switches on same plate but to my mind, and as you've suggested, they should be seperate, but they are not. One sleeved wire goes into each common terminal on each switch but the L1 connected wires are swapped between the two cables, which just doesn't make sense.
Going back to your original post, I'd need to ascertain the live feed and the output feed in the ceiling fixtures (both have the same amount of wires so I assume this isn't the end of the chain) then go from there... or call an electrician. Thanks for your help anyway Pat.
That wiring does sound odd. But there is no way to end up with the lights in series (as must be happening to have them glow dim) unless one of the lights isn't connected probably to neutral. if both lights have one side connected to neutral then they work or they don't (or it goes bang) so my guess is the feed to the second light is wrong.
Pat, thanks for your input, I think you are right that the feed to the second light is wrong somehow. I also think the switch wiring is wrong. With a clear head tomorrow morning I'll re-read all of your posts, have one last look (with the juice off) and if no joy then I'll call a spark. Thanks again for your most intelligent responses.
Tony, feel free to post a picture of the switch wiring tomorrow. If it's a simple fix I'm sure someone will point it out.
Take serious care when investigating
I don't believe in god but thanks for the sentiment. My father is alive and well.
I don't either, it was just a figure of speech. Funny how a lot of statements of exasperation can centre on religion! Oh for Christs sake!, Jesus!, For Gods sake....and so on. In fact it is sometimes hard to find one off the cuff that is not so inclined. Can you let us know what the unfortunate Electrician that gets that call uses for an utterance when the above is re-iterated to him upon his arrival?
Will do, hoping to return good news about nine wires...
Honestly, I'm humbled. As a software developer I'm used to dealing with complexity but this has me stumped, if I can get someone in who can say "I know!" my hat's off to them.
Lights glowing when they are off, as has just been said by Snowhead!, indicates that the light is getting a supply from the neutral of another light so both lights in series gives a dim glow as they are at half voltage.
Wot these two chaps said. Don't start taking switches off and making the problem worse. You've just messed up the connections in the light, unless the person who put the light up originally did!
Employ an electrician, who will terminate the cables slightly better anyway.
I'm sure 'bigsparks' is actually Davesparks in disguise. The forum seems to be going the way it went ages ago, ie. downhill. Oh dear. Daz
Can we get back on track guys, I've deleted several posts relating to poor and dangerous advice given by a member, a PM will be sent regarding the post, can I please ask you again to report such posts as oppose to pulling the thread off topic and or lowering the tone with personal attacks on other members.
