- Reaction score
- 25,522
See, simples.Or if the trays long enough I can just rest it on the bottom.
Discuss Using a cavity wall gap for cables in the UK Electrical Forum area at ElectriciansForums.net
Used to be done as a norm many moons ago, but rules change, Regs change.
Sure it is the bottom you are seeing. I have pulled cables up my wall cavities but used the water bond from the CU to pull a draw tape through.Luckily I can see the whole of my route from top to bottom. Luckily these brickies seem to have been a little better.
Assuming they aren't knotted you could use one to pull a draw wire in then pull it back down with the new ones.Yes I can see the current CCU cables come into tge cavity and some go down to under floor and some come up to 1st floor and loft.
There are a few spider webs in there and sadly a few cacooned flys.
Reply to Using a cavity wall gap for cables in the UK Electrical Forum area at ElectriciansForums.net
