- Reaction score
- 0
Discuss Vintage display cabinet lighting in the Lighting Forum area at ElectriciansForums.net
Or connect to a MF JB if requiredReplace it with a 13A plugtop
But you would need a 13Amp socket to plug the 13Amp plug into according to some that don't know what a plug top is LMAOReplace it with a 13A plugtop
I'm sure Winston will be along soon to explain thatBut you would need a 13Amp socket to plug the 13Amp plug into according to some that don't know what a plug top is LMAO
Hope he can, explain it that isI'm sure Winston will be along soon to explain that
I'd guess Germany - the embossed "gepruft" translates as "checked"Interesting plug top that
Where did the cabinet originate from ?
Never in the field of Human conflict can so much be owed by so many to soI'm sure Winston will be along soon to explain that
If you had a 13Amp socket to connect it to!!!!!After inspecting and testing the equipment to ensure that it is safe and suitable for connection to the UK mains supply you could fit a BS1363 plug with a suitable fuse.
Reply to Vintage display cabinet lighting in the Lighting Forum area at ElectriciansForums.net
