A
Adam byrne
Bonjour I'm a level 3 apprentice at the moment and have a side job to fit a double socket for a washing machine, only power is off a fuse spur supplying a gas boiler, which is also protected by a 13a, is this okay?
Haven't taken it off the wall yet but from what I know, it's off a 13a fuse, don't know what it's wired in yet but from the Spur to the Boiler it's 1.5mm flex, don't know what's going into the spurwhat cable/circuit supplies the boiler? it maybe possible to use the 13A FCU to feed the washing machine and then add a 2nd FCU (3A) to spur off to bolier. all depends on existing circuit arrangement.
Depends how the boiler spur is wired, is it off of a RFC or a separate radial solely for the boiler?Haven't taken it off the wall yet but from what I know, it's off a 13a fuse, don't know what it's wired in yet but from the Spur to the Boiler it's 1.5mm flex, don't know what's going into the spur
It is yeah, breaker is purely marked "central heating"Depends how the boiler spur is wired, is it off of a RFC or a separate radial solely for the boiler?
What size is the cable and the breaker?It is yeah, breaker is purely marked "central heating"
Haven't checked yet what the cable SUPPLYING the fuse spur is yet but it's a 16a breaker but I don't think it's a radial, How do I tell?What size is the cable and the breaker?
By carrying out dead tests on the circuit.Haven't checked yet what the cable SUPPLYING the fuse spur is yet but it's a 16a breaker but I don't think it's a radial, How do I tell?
R1+R2By carrying out dead tests on the circuit.
Firstly as an apprentice do you expect me to know everything? How am I suppose to learn this trade without asking questions? Did you know how to do everything at 18?Nothing wrong with asking questions , but you should have a think about it first before replying , it's okay to ask for pointers but it's not okay to ask someone to tell you how to do the job
