Hi All
On a job this morning doing an EICR. As you will see from photos main live conductor showing signs of burning out at termination. Checked tightness of termination and main switch all seemed fine. I thought I would check main fuse rating to see rating of this. Supply is tncs with 16mm live conductors and 10mm main earth. On checking main fuse I come across what you can see in photo. A hollow round tube in fuse link terminals. This surely isn't legit? The fuse was sealed so I assume it was supplier that put it in
It's not a fuse it's a link!
This is fused upstream somewhere.
There will be an incomer to the property, at this point it will split into several fused supplies - one to each flat for example.
In the flat there will be a link - clearly marked as it will have a dark red / maroon coloured holder.
It was this one.
You need to find the main incomer to the building.
And be wary of pulling main fuses, this should be left to suitably trained and equipped persons.
No idea why you pulled that sealed link.
Judging by the photo of a burned conductor at the incoming switch I presume they were going to replace the cable & switch so needed it off?
[automerge]1591102494[/automerge]
I guess curiosity resulted in them opening once out...
OK I should have read the text more carefully, no replacement just checked tightness. Doh!
London
United Kingdom
What the hell is this main fuse?
JohnS888,
freddo,
