Discuss What will I need for new build work? in the UK Electrical Forum area at ElectriciansForums.net
Agreed, but not for the soft blockwork used now days in house construction, that's usually only on the garage /kitchen wall! the rest will be timber framed.
Most houses over here are still block construction on the ground floor, with studding only used internally on the 1st floor. If I have to drill a hole in block it's not a great hardship to pop in a plug, rather than use a much more expensive alternative - for timber framing wood screws still work as well as they always have.
Concrete screws definitely have their place, but I'm not convinced it's holding lightweight electrical fixtures.
An idea to deal with the going out of adjustment problem...
Why not get one with fixed sizes such as this:
The ideal T-stripper style are not VDE insuated, but for most work (especially the ones for thin instrument wire) work really well.
The thing I like about the one I showed is that it will get into and work in confined spaces - no need to be able to pull it sideways.
If you just have one, it's cheap enough to have along with all the others, for when it's handy.
I never said they did, personally I would never use them, it was just an alternative I was pointing out as available, nothing beats a plug and screw. (help yourself)
Why? Why not get one with fixed sizes such as this:
Wickes did (may still do) a version of this that actually had correct UK sizes on for a nice price - was my standard for years before I found the CK strippers, and a set of Knipex installation pliers.
Still have the issue with cutting close in backboxes that needs a different tool (Jokari) - someone please design a tool that works for all those scenarios, is small, and also less than £20 please thanks...
Reply to What will I need for new build work? in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Quite a few new builds are popping up locally in my area. I have noticed that they are not even being first fixed until the buildings are...
Good morning all, long time reader first time post so looking for some help I’m qualified as an electrician but haven’t worked as a sparky for...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
