Discuss Whole Kitchen wiring diagram advice (excluding lights) in the DIY Electrical Advice area at ElectriciansForums.net
I don't understand what you mean, sorry.
Anyway, I've given my opinion. Hopefully you can move on with a suitable sparky who will design, install and test a suitable solution.
Pardon me, This Was regarding your notes about "limit of knowledge", you admitted that you would do not want to change your opinion regardless if there will be conflicting information coming from more qualified electrician, so this mean you where ashamed to admit limit of your own knowledge (potentially) . And yet you are asking others to be shameless in this regard ;)
Interesting idea regarding the split groups. I can see by the amount of opinions this is more like art than precise science. Thank you for your input. Regarding "2" I just need different opinions from professional as I have being let down by them occasionally
What I posted was NOT a recommendation as to how I would lay out your circuits, just an example of how I would deal with quoting for a kitchen fit out.
Take no notice of me, I am not even registered to provide part P certification so cant be bright enough to do domestic installations.
however I do know a bit about electrics and the ins and outs of customer/contractor relationships and that was where my post was aimed at.
Look, your original idea was not good. I advised there were two many high power appliances on the one ring circuit, which I stand by. Others also agreed with this.
It's no good you just tinkering around with things when you aren't aware of the regulations or reasoning behind them.
If someone wants to disagree with me then I'm fine with that. As I said, I only one person.
Up to you. Feel free to 'design by screwfix forum' if you wish.
it was not just Screwfix but local qualified certified electrician as well, the only change he made is splitting hob and oven. there is an updated version of diagram with 2 c rings and separate hob/oven. Yet you don't want to admit your own limitations. And should I state the obvious that anyone who is asking for advice here in diy section is admitting his limitation by definition. please
Hi everyone,
please advice and comment on the attached wiring diagram for a kitchen.
There are mixed opinions on the need for FSU-s and number of circuits required.
Distance to cu – 8m running under timber floor. kitchen size – 3.5M X 2.5M
Is this a !960s house ?
I agree with DPG about the single ring main.
Fridge /freezer
Hot tap
Boiler
Ideally, should be on their own circuits
If you're running out of Cu ways, you could always add a small kitchen Cu and have more radial circuits.
Competent or qualified ? As there is a big difference.
Fridge /freezer
Hot tap
Boiler
ideally I would live on Tenerife :) what is Within regs is fine by me for now ( the house is 1890s))
Fridge /freezer
Hot tap
Boiler
thank you! is this any closer to ideal?:kiwa7.png
Reply to Whole Kitchen wiring diagram advice (excluding lights) in the DIY Electrical Advice area at ElectriciansForums.net
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
