Screwfix has its' uses,but they DO have some very poor items,tools especially. I recall a friend purchasing some cheap circular saw blades,and on testing them,discovering a better product could be sourced by using a similar sized pastry pie lid,with pieces of Toblerone inserted at the edges...:icon12:
that was his problem, buying cheap.
tlc is good but its little far cant go much often, they deliver next day too.
cpc, rapid online
screwfix has plenty of branches around, average quality
toolstation some things are ok, some not, good for spotlights and led lamps. .
local wholesalers not so nice, good prices for members of the club, and im not a member.
Is that an accumulator ?
Similar.
You see that band around its middle?
Well there's a neoprene diaphragm held in place by that and it divides the inside of the thing into two hemispheres.
The top half is filled with nitrogen gas at 0.5 bar. and there's a Shraeder valve (car tyre) valve sticking out the top to allow for replenishment.
The bottom half is empty and there;s a half inch bsp fitting to connect into the rising main of a building water supply.
The idea is that if there's any water hammer in the supply the shock of said hammer will be absorbed by the nitrogen pressing on the other side of the diaphragm.
Combi boilers don't like water hammer and for some reason my house supply has recently acquired water hammer that I can't get rid of so this Shock Arrestor (AKA Mini Expansion Vessel) has beeN purchased for fitting when health allows.
The cost is less that £30 but it could save my £1000 boiler from getting shagged.
EDIT!!! .. I beat the swear filter!! Happy Happy Happy!!! :hurray::hurray:
TLC for me
Im not sparking 100% of the time now so can't build a good relationship with a wholesaler but even when I was I found wholesalers didn't give as good service as TLC does. Never had any problems with returns or deliveries and never been stealthily charged £17 for a bog standard 20A DP switch!
...The bottom half is empty and there;s a half inch bsp fitting to connect into the rising main of a building water supply.
Yeah. I noticed that you'd slipped the word 'bottom' in there. :biggrin:
whats tlc
Search for "TLC Direct", though I think they only cover down South (plus Wales). I use them a lot, again very good service, no problems with returns. My only small criticism is it can sometimes take a while to get served, at least at the Slough branch I use, if it's busy.
Similar.
I have used a similar thing (higher pressure) on hydraulic systems to smooth spikes when we had a series pump bodies cracking.
Aye, they have lots of uses - including motor car suspension. Citroen & Rolls Royce spring to mind.
Citroen got there first & R R saw it as a good idea & adopted it.
Screwfix or should I say electrafix are up for negotiation, I have a email for my local branch, big ordered they can help you out. It's handy when you need a bit of everything.. Mind you still use my inderpendant dealer for most stuff.
Description for such devices,range from Plenum chambers,Hydraulic dampers and System-cushion,the last one being a translation on a Japanese machines service manual.
Heavy plant with high carried load,such as a dozers' lift arms,have them downstream of any safety valving.
A good example of using plain old air as a "cushion" is the function of the hemisphere,in a Primatic cylinder,where its' operation is assisted by a mere bubble...
I did some work for a pal of mine,who installed four of the biggest,sectional radiators,i have ever seen in a domestic setting.
He bought them in France,and had them re-furbished,the largest weighing 350 kg.
The massive increase in system capacity,had to be catered for,expansion wise,by fitting a giant expansion vessel,which we simply tee'd off the CH output,near to the boiler. I think we had to measure system pressure cold,and pump vessel up to the same,plus a bit. :icon12:
I have had Lamps from TLC, delivered to Carnforth, but that was by order not by Local Branch service.
Return service ok as 1 off lamp damaged, quickly replaced after contact via telephone.
Like this --->>
"Hello Geordie Spark",
Can I suggest that You test your Home`s Water Main pressure regarding altering the pressure in the `Shock Arrestor` vessel - and as the Mains pressure will fluctuate throughout the Day and from Weekdays to Weekends it might be impossible to get the vessel pressure correct to stop the Hydraulic Shock in your Water Main.
I think that the vessels come pressurised to about 5 Bar from the Manufacturers - this would probably be too high if your Mains pressure is well below that - as there would be no `give` in the membrane.
I have fitted these in the past and I have also always had to alter the Mains pipework - usually in the Roof space - so that the Pressure surge that causes the Hydraulic shock goes `directly` to the Shock Arrestor - i.e. that it is fitted at the end of the Water main pipe run - IF possible - although as you know often the Water Tank Ball-valve [`Float-valve`] is at the end of the Mains pipe run.
In my own Home just after I fitted some new Bathroom and Kitchen `Quarter turn` taps there was a slight increase in the average pressure of the Water main in our area - only about 0.3 Bar increase - immediately the taps being turned off as usual / now `too quickly` was causing Hydraulic Shock in our Mains pipe - I tried to just get my family members to just turn the Taps off slower but they just could not get used to it.
After testing the Mains pressure at various times throughout a couple of Weeks / Weekends I fitted a Shock Arrestor similar to what You have pictured - our average Mains pressure was about 2.5 Bar - with momentary Surges to 3.5 Bar [causing the Hydraulic shock] when the Taps were `turned off too quickly`[/B
Trying various vessel pressures including equalising the vessel pressure with the average Mains pressure also did not work - one might think that with 2.5 Bar on either side of the vessel membrane the vessel would then `take` the 1 Bar surge and eliminate the Shock noise - this did not work at all times - nor did pressurising the vessel to 3 Bar - and at times when our Mains pressure goes down to about 2 Bar [Evenings and Weekends] the 2.5 Bar vessel pressure possibly distorts the membrane fully into the shape of the vessel - but at 2.0 Bar we don`t get the Hydraulic Shock when the Taps are turned off too quickly.
I think that I remember that the maximum pressure rating of my Shock Arrestor vessel is 10 Bar - But obviously the actual pressure behind the membrane cannot be increased to anything like that - I would not want to go above about 4 - 5 Bar [maximum] and the membrane of some [cheaper] vessels might not be able to take anything like that pressure - I think that my vessel is from Altechnic or RWC [Reliance] so a `good quality` fitting.
I have left the Shock Arrestor in place for a few Years - BUT I don`t think that it has ever `done the job` of preventing the Hydraulic Shock in my Water Mains pipework - my Family members have just gotten used to NOT turning the Quarter turn Taps Off `too quickly` - verbally encouraged by Me !
I wish You luck with the Shock Arrestor - IF You have good Mains pressure at your Home I think that you will be messing about with a Foot-pump quite a lot - also there is such a small amount of volume in the vessel that even just disconnecting the Pump from the Schrader valve probably negates more of the pressure than one might realise - getting an accurate / correct vessel pressure could be a problem.
You might be able to just fit it and find that it `does the job` - I hope that this is the case.
I am sure that You will have already decided to do this - I would always fit a Full Bore Ballofix type valve under the Shock Arrestor - that way you can easily take the vessel off the pipework to pressurise it if necessary.
When You are able to fit the Shock Arrestor I would be interested in how You got on - perhaps via a Private message if you don`t want to reply to this message at a later date ?
Regards,
Chris
were do most shop im finding of late screwfix to be cheaper than the local wholesalers your thoughts
Screwfix for sure, the Wholesalers just can't compete,
It might just be my local CEF but I find I'm stood round for 30-45mins every time I go there, while they continually bring me the wrong things then go back to find the right things,
then I always find the invoices are wrong and always extra things I didn't have. so I have to mess around getting them to correct it every time I go.
Also I cant quote using materials from CEF cause I have no idea how much anything costs so I have to call them and hope they get all the information correct then wait days for the quote to come through
where as Screwfix I can quote the same day, are cheaper on everything than city's, and I can order it all on my phone, hit the "I'm here to collect" button on the app when I pull up outside and the stuff is on the counter by the time I've walked in
And other than the LAP crap, their gear is just as good, if not better
I use Mk Logic sockets from Screwfix which look the -------s compared to the square bulky Scolmore crap I get at citys for the same price
Only time I use Cities anymore is when I need something specialist they don't have at Screwfix
