Discuss Widow(er) maker..... in the UK Electrical Forum area at ElectriciansForums.net
Metal CU;
Brown & blue tails serving a shower sub-board (Don't know why they didn't use the spare ways on the rcd side!)
Flanders - don't worry, there is a mixed colour label on the cover, so all's good:eek:
Because it's an 80A RCD with 64A of OCPD connected to it already?
They did the 'bang test' and all was good so what could be wrong?!
Not happy looking at that - I'm getting some good standards in my training which pleases me, I even get a bit picky with the other mates I work alongside - well I don't want them to be producing sloppy work do I ?
I have come across this probably 10 times in the last year carrying out reports.
Effectively by having the cover off with that RCD still live you are breaching EAW Tegulations.
Breaching EAW would be the least of my worries! Switch off, carry out your safe isolation at the bottom of the main switch - all good; touch the lhs busbar, bang (and possibly dead).
This is a top post Polo !
A new step in the safe isolation procedure - check for sneaky supply that bypasses the isolator ...
Worse that the RCD not being on the load side of the isolator is the unprotected circuit leaving the CU on the brown and blue also in the top of the RCD.
I have seen a similar house where the tails came from a main isolator (from a 100A fuse) in 10mm² to the first board, the second board was tapped off the incoming terminals of the first board and the third board was tapped off the incoming terminals of the second boards RCD!¬
Ps, it's a 100mA RCCB, yes that's 2 rings in one protective device, yes a 2.5 radial is doubled up in a protective device with a ring, and if anyone knows what type of 3871s they are then that would be fantastic as they were not written on.
Edit, Oh and the 6mm brown is feeding a shower!
Another MK (Sentry?) board. Any chance they were built like this....surely not?
Reply to Widow(er) maker..... in the UK Electrical Forum area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
  • Locked
5K
