Discuss WiFi switch won't work. Two lights two wires. One switch in the Electrical Appliances Forum area at ElectriciansForums.net
Hey guys
So I tried to change my light switch today to a WiFi on
When I took the switch out there were two live wires. One brown and one blue with a brown casing on it
I hooked up the wires as stated and that were similar to what the origin Al switch was set up to The power came on the switch.i did the wifi set up etch.
But the lights just won't come on at all An do have no idea why. I have two lights on the living that at Co trolled by the 1 switch And only the two wires behind that powering it.
Can anyone help as to why the lights won't come on e en though there is power going to the switch It's a so off light switch ( I think.)
I can take pics of that helps
I'm. Just confused as to why it won't switch on the lights So frustrating
Then you cannot use it, unless you provide a neutral at the switch.
That will need a replacement/additional cable to be run from the light to the switch.
Not easy this electric stuff, is it?
PS, to be helpful, can you explain what you want achieve with this wifi switch?
If it is just to control a lamp, you can get lamps that can be controlled by WIFI, APP,ALEXA, etc just by swopping the lamp.
THIS sort of thing
Hahaha it really isn't
I'm gunba look for switches that don't require a neutral.getting a neutral. Wire would cost a bit?
Nah its for. The big lights in the living room. I don't want a bulb want Switch I like the look
Thank you :)
Reply to WiFi switch won't work. Two lights two wires. One switch in the Electrical Appliances Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
