Discuss Wiring a extractor fan ??? Help please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
James.
Hi Ive just bought a unwired 150mm two speed extractor fan and im having trouble wiring it up
Ive made up a pic. as best as i can of what it looks like .. Id like to have it wired to the low speed setting,s . I have marked high and low speed on the pic
I hope someone can help me out with this and im a well known danger when it comes to electric
Thanks in advance
Thanks in advance
Whats the black box?
You need to give us a better drawing to sort it out.
The black box is the electrical motor. sorry i should have stated that .
I dont know if this pic will help better i copyed the writing from the wiring instructions the long grey box is the terminal box
It looks like `grey box` is a circuit board with in-built resistors to drop the speed down. Is this correct?
Try rigging up a temporary supply from a plug-top (3amp fuse). Connect live into LL and Neutral into N. If those wires are soldered on to the circuit board - make sure you tape up the wire going to LH to prevent back-feeding.
Yes m8 you got it spot on once you says that i figured how it worked , The wires are not soldered they screw in i could have tryed harder with my pic sorry . but you told me what i needed to know :)
the way i had it wire was wrong to start with even know it was giving me max speed still .I had the live in LL and the neutral in LH :eek:
But now i know Neutral in N and live in eather LH or LL for high or low speed .
It seems so easy now once some 1 put me on the right rd nice one m8 thank you
Or spend a bit more and buy a fan which is a little easier to understand and wire;)
I did spend a few quid on it i thought you would have got it stright away :) Cool site
Reply to Wiring a extractor fan ??? Help please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
