Discuss wiring heating systems in the Central Heating Systems area at ElectriciansForums.net
T
tornadoarnold
i am looking at doing some work with plumbers doing the wiring for heating systems in houses and could do with a bit of advice as i haven't really done much with them before.
anyone got any good links for diagrams of the different types of circuits used for various systems used.
any ideas on time frames to wire these systems as well would be very useful. obviously if it is just putting in a fused spur for a combi boiler it shouldn't take too long, but on other types of system, are we talking doable in a day or longer.
cheers
cheers
Is this any use to you?
UK DIY FAQ
Wiring diagram for Central heating system - DIYnot.com - DIY and Home Improvement
Reply to wiring heating systems in the Central Heating Systems area at ElectriciansForums.net
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hello! I've just moved in to a new property with "all electric" heating system and trying to figure it out. The agency/landlord are of no help so...
