This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
J
James73
Would the wiring on this Sunvic cylinder thermostat Sunvic SA2452 Cylinder Thermostat 3KB Pic 1
be the same as this Sunvic 4KB Pic 2
Why does it matter? You could use any surface mount cylinder thermostat. They will all have common, N.O and N.C contacts.
I think it should be the second one is just the new design of body for the same thermostat.
three contacts: one common, one normally open (NO), one normally closed (NC).
get a plumber to fit it, then take all the broken bits back for a refund.
man invented fire some thousands of years ago, and ever since, other men have been trying to make it work.
James73,
Leesparkykent,
