Discuss Wiring thermostat in the Central Heating Systems area at ElectriciansForums.net
James73
Would the wiring on this Sunvic cylinder thermostat Sunvic SA2452 Cylinder Thermostat 3KB Pic 1
be the same as this Sunvic 4KB Pic 2
get a plumber to fit it, then take all the broken bits back for a refund.
man invented fire some thousands of years ago, and ever since, other men have been trying to make it work.
Reply to Wiring thermostat in the Central Heating Systems area at ElectriciansForums.net
Hi I'm trying to figure out how to swap my standard myson thermostats for WiFi enabled ones - going to start with the simple one first - the one...
Hello, I'm trying to upgrade my mechanical thermostat to a wireless one but when I connect the wires it doesn't work. This is the old one: And...
I currently have a Myson thermostat that is no longer working. I have a Meross thermostat to replace it. I have attached photos of the current...
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
