R
richardshall
Hi guys,
I have got a circuit breaker in my workshop and i want to use it to run lights, sockets for tools and some outdoor lighting and water feature ect.
I have already connected the end to the new circuit board in the shed and run the armoured cable underground to the circuit board in the house but i am unsure where to connect it. Can it be connected directly to the red main switch the same as the existing board or can it be connected to a circuit breaker on the panel. I was advised to connect it to a 50amp breaker but i have been having problems with it so i disconnected it.
Any advise very much appreciated.
Rich
so many factors to consider. size of SWA cable. earthing system, shed construction. not to mention notification under part p. only advice i can give is to call in a registered spark.
Hi thanks for the reply. the cable running from the house to the shed is armoured and is approx 10 -15 mm thick all together.The shed construction is out of shiplap and a timber base. Im not sure about the earthing system or the notification under part p that you mentioned.
I would prefer to do it myself as i am self employed and dont have much time to wait in for people, plus theres the cost.
Any info again would be appreciated
Well the simple fact is you are not compitent enough to be undertaking this work!Its downright dangerous to even attempt it.Do the right thing and employ a spark!
to be honest, mate, each to his own. weigh up the cost of a professional spark against the costs of 1. notifying building control ( about £200 - £300 ) to comply with the law. 2. the possibility of your house burning down.3 . the possibility of you or your family being injured or killed. it's a no brainer mate.
i wasnt aware that you had to notify anyone just to have electrics into a shed. I fully understand about laws as i am a business owner myself and yes it is a no brainer and i would never put my family in that situation.
Please do not connect that cable to a 50 amp breaker, 10 -15mm diameter does not sound at all like it can handle 50 amps. Call a qualified electrician.
that advice did come from a qualified electrician lmao, what a joke with all due respect theres someone on here saying im not compitent enough and people saying to call an electrician and i was told to wire it up to a 50 amp breaker by a qualified sparky ffs doesnt gine you much faith tbh.
richard, google part p. you can download the part p doc. this tells you that certain electrical works must be notified to your LABC ( local authority building control). amongst the works that must be notified is any electrical work outside and/ or involving new circuits. if you were to do the work yourself, you would need to notify beforehand. then they charge you a goodly sum to check/inspect/test. if it's wrong, they will make you rip it out and start again. you are then around £2-300 out of pocket with nothing to show for it.
by employing a registered spark you are then.1. getting the job done correctly and safely. 2. all the notification to comply with the law is taken care of.
Hi Ganz thanks for the reply ....it was working fine at first, i had the lights connected as well as a single socket wired temporarily. I connected an extension lead to the socket to run a grinder and something tripped and now part of the board works and the other part dont. i reconnected a new socket as i thought it had blown the socket and tested it by switching the breaker onto the on position and it set the electric smoke alarms off in the house (i honestly dont know why and i admit that). i havnt used it since.
so you have to pay just to have electrics in a shed. I know loads off people with outdoor electrics and electrics in sheds who havnt had to go through all that, How come ???
just go on your local council website and look up building control the info is there m8
it will clearly explain for you to get a proffesional
Nobody on here can give you the correct advise other than get a electrician in.
We would need to know every aspect of your installation including lengths and cable CSA's in order to give you any other sound advise.
If you have a wife and kids, please do not do any more and take the advise you have been given and get someone in.
