B
bode2008
I am looking for an extension lead or fitting which will allow a standard UK 3 pin household socket to be connected to a bayonet light fitting.
I understand tradesman use this type of extension lead when working in lofts where there is no electrical socket.
Has anyone come across this or know where to obtain one?
Thanks.
Hi8 bode
this tyre of fitting used to be common ,havent seen one for ages ,try an old type d,i,y store or ironmongers ,i use a extention lead myself with a 500 watt halogen,what if theres no fitting in the loft ,what then?
atvbitwww
I have attached a bayonet fitting to the end of some 2.5 flex with a plug on the end and use that. 500W is great but don't really wanna see what is lurking in the loft space!:eek:
Someone suggested to me that this type of fitting may have been banned because of new safety regulations.
I need to plug electrical items into an area which cannot be reached by an extension lead without some risky drilling through walls.
Where did you get the bayonet fitting?
This will need to be plugged into the light socket and have a standard socket.
Not an expert in these matters but if anyone would like to make one I'd be happy to pay!
Try a couple of croc clips on the pins in the lamp holder;) ,be ok if there insulated ,cheapest way out of it ,by the way is it electrical work youre doing?:)
all the very best
He wants to connect a 13a socket to the light cirrus
all the very best
No I'm building a photographic darkroom in a room with no electricity apart from a light socket. I had considered drilling a hole through a wall but there are too many gas and water pipes so would prefer to avoid that area.
The apartment is rented so there's the hassle of permission etc.
If you can see the pipes you should be able to drill a hole without hitting them ,what size load does your photo equipment take ? will you have computers ,t.v or an electric fire up there,?
is there a fuse spur for an immersion heater,?
if so change that for a socket:D
The electrical equipment to be used are two safelights which are just simple pygmy bulb lights and the enlargers are big expensive stands with light bulbs.
A little googling has found the term "bayonet plugs"
They were around years ago but most likely banned due to safety issues. Not sure if there is a safe version.
hey just a thought ,you wont have an earth if you come off the light,and these old fittings ,are they safe ,how do you know ?
sounds like you nead to get someone in pall
all the best for now
Not sure if they've been banned but there are a couple of glaringly obvious safety issues here.
  • Earthing - as someone has already pointed out.
  • Over loading the cable / circuit - Most lighting circuits will be wired in 1.0mm cable, some 1.5mm. OK, so the fuse or MCB should only be rated at 6a or 10a respectively thus protecting the cable and should therefore trip before any real damage is done but even still, it's never good to over load a circuit.
  • Chances are, the lighting circuit will not be RCD protected.
OK, so you've said that you're only going to be powering lights from said circuit but I wouldn't advise running anything from a bayonet fitting other than a bayonet bulb.
Is this going to be a permanent setup or is it just for a one off use? If permanent then just invest in some electrical work. Please, do it properly - it'll be worth it in the long run.
Regards
It reminds me of when my mum used one of these connectors for running her iron off when plugged into light socket back in the sixties when only had a single socket in living room and wanted to watch telly.
Thinking back it's a wonder the house did not burn down using one of these things.:eek:
A little off topic, but I did a rewire for a housing association a few years back. The tenant in the house was a 89 year old man who had lived there all his life.
There was only one single socket in the house and he used to drag a long lead from room to room. Our rewire included the installation of numerous sockets throughout.
When I returned some 6 months later to see to a lighting problem he was still dragging the lead from room to room. Old habbits I suppose.
Thanks for the advice, I'll see if I can get an extension lead through the wall or see about getting a socket fitted.
working in areas without sockets.
Talk Electrician Forum
bode2008,
bode2008,
