R
Redvanman
Only if it's outside the zones that is
Yes , greater than 600mm is outside the zone so you can use light switches in that area as long as all circuits are protected by an RCD ,
You picking and choosing regs here and forgetting others... You switch is required to be suitable for the environment its placed in and as the bathroom is classed as having a high humidity and steam environment then a standard switch is not suitable as they do not provide good IP rating - the steam will condense on the cold plastic .... have you not seen this happen to the mirror?
This ^^^^ - Wet hands on an already steamed up switch - don't sound right, does it?? - regardless of where the zones begin/end
this is it...This ^^^^ - Wet hands on an already steamed up switch - don't sound right, does it?? - regardless of where the zones begin/end
