I
ianbrookes
hi, I have installed one of these switches which is controlling two external light fittings - they are KSR Lyra 80 3W LED Spot Lights.
The timer switches the lights on as expected when the time program ends the lights switch off but then they start to flash continuously.
Has anyone seen this before ?
Manual operation is fine.
the Sensor mode is not used (so not a sensor issue).
thanks.
Have you metered across the outgoing terminals when the switch is in apparent off position?
You say it works fine in manual mode?
I have a similar issue with a timeguard switch on an immersion, i disconnected everything in the switch re connected it was fine!! Weird but i couldn't put it down to anything?
