Discuss ZV700 Timeguard 7 day digital lightswitch issue in the UK Electrical Forum area at ElectriciansForums.net
I
ianbrookes
hi, I have installed one of these switches which is controlling two external light fittings - they are KSR Lyra 80 3W LED Spot Lights.
The timer switches the lights on as expected when the time program ends the lights switch off but then they start to flash continuously.
Has anyone seen this before ?
Manual operation is fine.
the Sensor mode is not used (so not a sensor issue).
thanks.
Have you metered across the outgoing terminals when the switch is in apparent off position?
You say it works fine in manual mode?
I have a similar issue with a timeguard switch on an immersion, i disconnected everything in the switch re connected it was fine!! Weird but i couldn't put it down to anything?
Reply to ZV700 Timeguard 7 day digital lightswitch issue in the UK Electrical Forum area at ElectriciansForums.net
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
Hi, I have a downstairs toilet with two spotlights. I have recently replaced the MR16s with two GU10 LEDs. This has meant that my PIR makes the...
We just moved to a new house and there are few projects I'd like to do. There are 5 external PIR security lights, 3 at the back and 2 at the...
I'm having a bit of an issue in my own garage which I'm hoping someone will spot what's wrong... Just done a complete refit, new board, lights...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
