D00DY_T00DY
Hey guys, did a loop circuit today going from a 13A connection unit to a ceiling rose and a 3 plate batten lamp controlled by a 1 way, 1 gang switch now it all works fine; Tested and then made live but i'm not sure how it works? so why certain wires connect here and there. It's easy following a wiring diagram but i want to know how it work any fellas on here able to explain it if you will? Appreciate the help guys
The live goes from the ceiling rose(First connection) down to the common on the switch through the switch up back to the ceiling rose and then goes to power the lamp, from the lamp the neutral goes to the ceiling rose and back to the source? is that right?
I know this is simple stuff but i'm proud of it before you lot give me grief *cough* GMES *Cough*
we used one length of twin and earth and cut it the correct lengths ourselves with brown sleeving to signify the switched live and for the second bit solely for connection purposes? so what will be powering the ceiling rose will be the switched live coming from the switch when it's on? the live from the spur is just to go through the lamp to connect with the switch?
