M
mazza
Hi guys
im currently starting my nvq 3 and am starting to buy some hand tools gradually. For my next purchase I want to buy a basic socket set that I can use on panels when using lugs etc or fixing equipment down! Can anyone recommend one please? I've seen this online but would it be any good??
Bahco BAHSL25 SL25 Socket Set 25-Piece 1/4-Inch Drive
Forgot to ask. I don't know about the size etc 1/4 or 1/3 or 3/8 and what I'd need!
I think you need to look for a 3/8in or 1/2in drive set with sockets from 6 to 17mm as a minimum
If it was me I'd say 3/8 as that a happy medium and you can go to small sizes and big with them, but I personally having an impact driver that takes 1/2 sockets would probably get the 1/2 set.
draper expert. about £40. the one i have has sockets that don't bottom out so you can run a nut right down threaded rod. i'll find the model no. tomorrow for you.
+1 for wera. expensive but worth it, pleasure to use and will last you a lifetime if you dont lose them
1/4 set for small bits and panels
http://www.amazon.co.uk/Wera-05073220001-Check-Single-Piece/dp/B005M2WJDW
and 1/2 for some bigger jobs.
WERA 05004078001 Metric 1/2-inch Drive Zyklop 8100 SC8 Metal-Switch Slim Ratchet and Socket Set (28 Pieces): Amazon.co.uk: DIY & Tools
How well does the case latch shut on them? I've got a bit of Christmas money to put onwards it you see and think its on the list of possibles.
Halfords have got deals on at the moment I think, and their professional range has a lifetime guarantee which they do honour.
The halfords stuff is great, I've got a halfords black industrial roller cabinet and I left the bottom drawer open by accident, was on steps, stepped down and put my foot in the draw Nd ripped it off the runners and told them and they swapped it for free.
I use 3/8" sockets as they are thinner walled than 1/2" sockets, so get into tighter spaces.
Can be used with judicious hammering on uni-strut.
SnapOn, and I imagine also Faccom and other quality tool manufacturers make 3/8" drive impact drivers.
bahco 3/8 socket set.
a little 1/4 socket set is very handy in your main bag upto 8mm bolts
remember m10 raw bolts use 17mm socket so you will need 3/8 socket set or bigger for that
to be honest your better off getting an impact driver adapter for how often you will use it
