Discuss max zs table in the osg in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all sorry for this silly question but i cant seem to find the max Zs table for a 10A BS88-2 Fusein the osg. I can find it in the BGB table 41.4
10A = 7.19 ohms and i know to multiply it by 0.8 (7.19 x 0.8 = 5.75) for rule of thumb but i would like to find the right table in the osg
Page 122 ???? I think thats right
yellow? i'm still on the red one. it's the same electricity whatever osg you use.
Use the value in the reqs but don't forget to apply the 80% factor
To be honest, i've never used this 80% factor and probably never will now!!
Can't see the point of why they need to mess around with proven values that have served electrical installations well for literary donkey's years...
i know your not in Britain, but if you were, surely you'd have to work to BS7671 requirements?
wouldn't not meeting these requirements constitute a C2
the figures are given in BS7671 without the 80% correction factor. these are what i use. in winter when we are measuring @3 deg.C, not 20, should we then apply another correction?
A C2 would be the code applied to a potentially dangerous fault found on an EICR, there is no such thing on an EIC.
If he has used values other than those in the books and recorded this deviation as part of the installations documentation then as long as the testing proves that the circuit is within those values there is no problem. Bs7671 is not the be all and end all of electrical installation!
Perhaps i should of also pointed out that the typical Zs values measured on our projects will meet and exceed anything that's presently deemed as max Zs values...
doesn't an earth loop impedance value greater than that required warrant a potentially dangerous fault, ergo C2?
which other values apart from the manufactures are there?
Reply to max zs table in the osg in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
