Currently reading:
Ze Values? HELP
Discuss Ze Values? HELP in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As a guide in the 17th the max Ze readings for the following =
Tns = 0.8
Tncs = 0.35
TT = 200
I Recently got a Ze reading of 0.15 on a Tns system, as its higher than 0.8 in the 17th should i be worried?
If its ok, what Ze readings would you consider high for each of the systems? e.g time to call the DNO.
Also filling out a certificate with a higher Ze reading than recommended in bs7671, allowed?
Tns = 0.8
Tncs = 0.35
TT = 200
with maths like that, you'll never make a scouse wheel thief. you'd nick1 and say it was more than 4!
Give the OP a break, most prob a brain fart moment....
Good grief!
Where exactly on BS7671 did you get that lot from?
There is no guideline maximum for Ze on a TT system, and if there was it's hardly going to be 200ohms is it!
Oh and 80 is higher than 15!
Tns = 0.8
Tncs = 0.35
TT = 200
Stop making out that scousers are thick
Hi,dude, You will have to grow a sense of humour,as you have only had 20% of the 100% normally given,which is,after all,only one seventh....:conehead:
0.80 implies greater accuracy than value than 0.8
Could it be that it was 0.8 exactly, with the zero dropped as it would be irrelevant, to the outcome calcs.
Sorry I'm trying to get my head around this, not disrespecting your post.
The zero is relevant to the outcome of the calculation as it will have an impact on its accuracy.
0.8 x 0.320 = 0.3
0.80 x 0.320 = 0.26
0.800 x 0.320 = 0.256
0.8 is a value anywhere between 0.75 and 0.84 wheras 0.80 is a value between 0.795 and 0.804
0.8 x 0.320 = 0.3
0.80 x 0.320 = 0.26
...Your calculator needs re-calibrating...:icon12:
Yes mate. If the 2nd, 3rd 4th etc decimal place is not required, dont need to use it or it would become 0.800000 or 0.8 X 10 to the power of minus 6 :wink: (level 3 maths, you will see)
^^ that is correct isn't it gents? Been a long time since writing this form of equation and it does not look right?
This is getting too in depth,anyone know if my maths are right,I seem to keep getting e=mc squared
Reply to Ze Values? HELP in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
