J.C.E
Hi all
1st fixed a new extension for a mate of mines job on Saturday (hes a builder- works for his boss)
was my 1st job for him- so I wanted to please him and get him on side!
Ended up putting 2 sockets on the wrong wall (mutual mistake- I put sockets where the drawing showed them- but they sprayed to be on a different wall- which I missed! -not to much work to move them anyways
But He mentioned 'wheres the capping?'
-I explained capping isn't REQUIRED- my chases are a good depth- and cable is clipped back- and is to be plastered over- and all circuits are RCD protected
Then he went on to say 'not allowed to chase into block work now (guessing he meant breeze).....which I told him is aload of bull!
anyways- going back to move the 2 sockets tomorrow- am I right to stand my ground with the 2 above points
cheers guys
you can chase into breezeblock, thermalite block etc. think there's a max. depth allowed vertical 1/3 of wall thickness, horizontal 1/6th.
Chasing into new blockwork is unnecessary, but not prohibited unless the structural engineer says otherwise.
Capping protects the cables from plasterers trowel and for most of is it's the way we were taught as best practice.
walls are rarely plastered these days. it's all dot & dab. in which case there's no need for chasing and no need for capping.
like tell says, its in the electricians guide to the building regs.
if you are not allowed to chase a wall there are bigger structural problems.
if it was a 4' hole through a supporting wall i might have understood his concern.
capping isnt needed and doesnt protect the cables from the trowel anyway
you must have some flipping rough plasterers round there.
Agree with davesparks, certainly way I was taught. OP why spend time chasing the wall anyway? If the wall is going to be plastered, the finished plaster depth, will cover cables clipped or cables covered in capping? Never liked burying cables in plaster, just don't seem right, like eating bugs!
Other than potential damage caused by a plasterer's float; what if the wall is going to be lined with thermal plasterboards that have the expanded polystyrene backs? PVC cables can react with the polystyrene over time. Fair enough if you're using new cable, but older cable is susceptible to insulation breakdown - a point worth thinking of if customers who are retrofitting existing buildings with existing, older wiring.
I'm coming across thermal boards more and more these days. Installing capping has always been cheap and quick, I don't see any reason not to use it and I always will do. By the time you've clipped cables to walls, you could have clipped capping to wall using same clips.
J.C.E
Earth
cable chasing
J.C.E,
shanky887614,
