"My cooker stopped working, can you call round and have a look?"
Lol
I had a call that every time the kettle was switched on the fuse in the FCU blows, but only when the hob is also on: double socket and 4 plate hob wired through a 13A FCU!
I had a call last week. Kitchen sockets are all off except 1, all circuit breakers and RCDs are switched on. Sure enough all that proved to be true.
Next to the working socket was a FCU for the under cabinet lights that had never worked. Yep, Kev kitchen fitter had wired the cupboard lights into the supply side and left the lights unplugged from the socket provided for them above the units. The rest of the kitchen, 3 above counter double sockets, fridge socket, and washer/drier socket were off the load side.
Washer had been put on, wife was heating up the iron, husband decided to make some toast, one blown fuse. I think the fuse did well to make it 8 years without popping.
Ive a garage to go and wire on Monday that is currently spurred of a socket in an upstairs bedroom, which itself is spurred off the ring. Into a consumer unit and then 2 radial sockets, one on a 6ft fridge freezer and the other a tumble dryer.
Which apparently had melted a socket so the homeowner put on an rcd socket. Lol
Tomorrow I'm going to speak to a bakery/sandwich bar/deli place, it's a complete balls from what I seen in the few minutes I had to look the other day, but by initial looks each circuit is overloaded, with ring mains running well over what it's capable of, and where radials are in place they are well under rated, and it will quite possibly require 3 phase to be able to supply the load from all equipment they have, the guy who was doing the work has been given thousands by the owner from what I believe, but not sure if he's legit as I can't imagine they've certificates for the place.
she was on holiday and back today, so will have a look over it properly and speak to her.
Not exactly the worst thing in the world, but we only let council electricians work on our electrics at work. Councils are renowned for their red tape policies, but I didn't think it was literal.
Thing is, I can't work out whether the tape is there as a barrier, or whether it's there to encourage the breaker to stay in the on position
If that comment is genuine, I suggest you find yourself a more suitable occupation, one that doesn't require any thinking, or common sense, like building site security at night or something like that.
I suggest we don't get into a war of words here guys, as I read it, hightower's comment was jovial and said in jest regardless of the mechanics of mcb which would still operate in a fault or overload as it still integrally trips regardless of external switch tab position.
If anyone here needs to have the finger pointed at them to find a more suitable occupation then it would be the person who put the tape on the CU and thought this was ok as oppose to one of our forum Trainee's.
Play nice guys :)
Reactions: 3 people
Reactions: 2 people
Atrocious ! And yet they still went to the trouble of clipping the cables where they enter the box in the 1st picture !:shocked3:
Crazy eh! Was doing an eicr and get some odd voltage readings at the switches, had to search for this junction box to find out what was going on, it was under tongue and groove boards in the loft, had to strip them right back to pretty much the last one, hate t and g boards!
Reactions: 2 people
Me too, ever quoted for a job that involves running cables through a loft only to find it's jammed full of crap and boarded out everywhere after you make a start ? :lipsrsealed2:
8K
Darkwood,
mainline,
