- Reaction score
- 7,784
micc on rcbo will not set
Discuss micc on rcbo in the UK Electrical Forum area at ElectriciansForums.net
to day I have changed a metal cu. micc cable on to rcbo will not set. I then exchange to mcb holds. this existing circuit
tested from live to earth on micc conductor on lighting all good
What have you changed it from? RCBO detects earth leakage MCB detects Overcurrent, so swapping from RCBO to mcb tells you what exactly, not rocket science is it?to day I have changed a metal cu. micc cable on to rcbo will not set. I then exchange to mcb holds. this existing circuit
What about N to E??tested from live to earth on micc conductor on lighting all good
not seen him on here in a whileAnother topic Dave Sparks would love.
Is the cable earthed?yes westward 10 the micc is buried in the wall
I don't think rcd protection is required but he would need to fully verify that.Is the cable earthed?
Reply to micc on rcbo in the UK Electrical Forum area at ElectriciansForums.net
