It is for the immersion heater it's what heats are water I've been using it since we have moved it but want something so I can put t on a timer rather than a switch?
In turn when I switch that on it lights this up and heats water?
Take a pic of the connection to the actual immersion and accessory it connects from and upload please
If you carry on you will either kill yourself, someone else, or cause a fire. An immersion heater is a relatively hi current appliance associated with water and bathroom pipework, and hence high risk. Leave it alone, you clearly don't know how to do it safely.
Mate that's a lighting switch, wired in what looks lie 1.5mm singles, there will be no Neutral at that position, so cannot be used as a W/H switch or any D/P switch for that matter.
If that's what they've used that as an immersion switch, you need an Electrical installation condition report as soon as humanly possible.
