If you are a member of Nic, Napit or ECA then SSE have a scheme whereby, as long as you inform them, you can pull the fuse for routine maintenance. They will supply you with temporary seals and will then reseal the service fuse. Details here:Removal Of Fuses.
Hope this helps
hi mate i cant seem to get to the link for the pdf is it ok and just my laptop
if so is there a way round it
On a Sunday?
You must be mad :D
playing catch up..!! Full Change including moving the CU 2 Meters Upwards.... nice easy job.
Singles all the way in surface trunking jointed to existing cables inside a IP enclosure with Wago!!
i replaced one of them Doepke heap of crap with a Volex Special..!!
what's better is i picked up about 300 quids of other works up at same time! NICE!
yes B&Q my way "Durham" ironically have stacks left!! going to get 2 more tomorrow! cant go wrong for 59.99
Free gifts !! :(
i got a thermal mug of b&Q for opening my Trade point account..! :)
well you get 10 free breakers in them and i dont use them all so thats free..! customer gets free blanks!!! :D
No, No No,
It was something like this:
:D:D
FOAM and WATER....!!! Electrical fire!!!!!!!!
tut tut tut........ head for the black label CO2......
my normal procedure is to install 100a wylex isolator (as used by meter guys, have a mate who supplies me off the back of his van) then if anything comes back i never pulled anything there was already a isolator fitted. not saying this is right , just my own personnal work around.
i still hold a valid pto (lasts 3 years and got 2 to go) so can always argue i was trained in fuse removal procedures.
Hello,
Sorry if this is a dumb question but what is the pto you are talking about?
