S
switched on
hi i have to wire up a few 3hp 5A 3 phase motors and usually use a 3 core swa but is there an alternative cable to use apart from singles?? Thanks for your help in advance
many industry driven motors have interlocked isolators, where a pair is also used, so when the isolater is in the off posistion the feed is also cut via a contactor
why do you want to use another cable???
SY cable seems more expensive and perhaps as difficult to terminate.
In an industrial setting mechanical protection is needed.:confused:
SY or YY is used as it is less vurenable to vibration than SWA and more flexable on incoming
I'm studying my HNC and I'm struggling a bit with motors, does anybody know much about three phase induction motors Cheers, Davey
Depending on the situation of coarse ! But I always prefer to see plastic shrouded armoured copex with swivel , top hat glands for motor connections as it gives good mechanical protection whilst still allowing good flexibility for maintenance and such like . It also means you can easily pull in new singles if ever needed which in turn I also find it a lot easer to connect singles into smaller motors and isolators as opposed to a multi core cable .
switched on,
JD6400,
