Someone has to think big, Steve Jobs didn't innovate by following the old rules!Not an optomistic ........... a straight disagree.
Anyway I've given you a friendly because you explained it's your opinion
True well that's the current system, in that post i was addressing the op issue as this whole thread seemed to have ended up about inconsistent opinions and how to get clarity on which is correct, what better way to get consistency than with a deterministic process.Or you could use the equivalent system already in place. Use your training and experience to make a judgement on site, take a photo to prove your findings, and digitally attach it to your report using your certification software.
One day there will be a crystal ball app, and you'll just take a photo of everything then it will connect to the servers and print out a full inspection report for you. Then you just need to do the testing and there will be a fully standard eicr with no room for argument (waiting for the optimistic rating there!)
Except without the benefit of an app, just a blank sheet of paper and a bit of imagination!I think this has already been invented - loads of low cost EICR's are produced like this every day
I gave one a Code 1.....definitely!My post is my personal opinion. I do not do EICR's so it doesn't affect anyone really. Just shocked to think that anyone would even consider giving a CU a C2 just because it's plastic.
Would it really? If there are exposed conductive parts with no earth, certainly, but if everything is plastic then it wouldn't be any more dangerous than any other class II equipment.1966 the norm was to install lighting circuits with no cpc but that today is classed as dangerous and would probily get a c2 but back then it was fine
Of course any more recent modifications would be c2 as they couldn't be added without RCD protection and cpc.
After your thoughts on EICR coding for an existing plastic consumer unit in an under stairs cupboard, firstly in a standard domestic dwelling and secondly in a house of multiple occupancy.
After discussing this others and with tech helplines seems to be a bit of a split as to what code!
Like who? I agree with you if your right but need a more to go on than that.JPEL /64 is stuffed full of manufacturers with profits to make ...
