That explains it then.the person who put the drylining in was the same person as the electrician
thankyou for your observation. Totally agreeA Dryliner didnt put that plasterboard up a butcher did. Horrendous cutting of a socket not only that it looks like he hasn't bonded around the socket neither.
the builder is the electricianthe builder must have asked himself. should the spark do the back box .ok then .![]()
i didn't dot and dab, the electrician did. The walls are solid stone and brick. Yes i agree very poor move for dot and dabInterested in what the external walls of the house are made of? Why are you dot and dabbing onto the external wall. We dot and dabbed insulated plasterboard onto solid stone walls in one room last year. We’ve since refurbished the whole house with lime plaster direct onto the stone as it has to breathe. When we removed the insulated plaster board there was a lot of damp between the two. Expensive business as the lime plaster is a real pig to work with.
no he's NICEIC qualifiedIs the electrician/builder a member of one of the NICEIC schemes?
