Stuart27
Trainee
OK, so this isn't really my thing, it's more my partners. She's really into all things spiritual and she came across this technique known as Spiritual Earthing(or Grounding) which I thought was quite intriguing and may have some scientific merit to it.
I don't fully understand the process but I think the concept is pretty simple, we're basically electrical beings that have been isolated from "Mother Earth" because in our every day lives we hardly ever touch Earth with our bare skin.
And by connecting our body to earth, electrons will flow, causing a balance in our electrical energy that will potentially have positive health effects..
So this gave me an idea and my question is this... Could I achieve this Earthing process by simply sewing some metallic threads into our bed sheets and connecting it to an earth point in the bedroom, from a light switch or power socket for example? Or would I just be exposing the bed (and us) to a potentially fatal fault current?
I don't think connecting an earth wire to our bed would be dangerous in any way, but I thought i'd ask the question just to be sure.
What do you guys think about this process? Have you heard of it before? There seems to be a lot of medical and scientific research gone into it..
Surely you could achieve the same effect by touching anything metal in your house that was correctly earthed?
A correctly installed electrical system should act as a Faraday cage so in theory there should be no danger in your proposal but that does depend on previous good quality workmanship and regular maintenance to ensure it is still correctly installed and if it isn't then yes it could be potentially dangerous.
I can't comment on whether this earthing idea makes any difference but I have heard of the idea from people I know who have more New Age type beliefs and like to dance or walk barefoot on the grass for this reason.
To be honest 90% of the members on here suffer from one or more of the following.
Below is a list of some of the more common symptoms of being ungrounded. Usually each individual will encounter the same one or two symptoms each time they are ungrounded.
Earthing Sleep, Grounding Sleep, - https://www.barefoothealing.com.au/c/night/5822 if I was going to do it I'd bond the bed to a radiator rather than an electrical outlet, combine the elements, earth & water :)
Looks like there is as much money to be made with this earthing stuff as with the 'audiophile' fuses.
If asked by a potential client I'd recommend a dedicated earth stake and earthing conductor, routed a minimum 450mm from all other cables in the house to ensure there is no induced currents or electrical noise.
Jeez I see some people are making good money out of this!!! I don't suppose anyone has any scientific proof of the benefits of being 'grounded'?
I can sell people earthing wrist bands if anyone is interested. I buy them for 2 quid on ebay, relabel them as 'healing spiritual grounding devices' and knock them out at 50 quid a time.
Only kidding by the way. But the guys selling the foil covered pillows must have big smiles on their faces. And not because of the grounding effects :)
Yes I have heard of it. Read the book Abramelin for further information. Ideally I should be done in the region of your place of birth. What do I think? It and so many other new age religions, ologies, isms, are essentially the doctrine of demons. These methods and means are all meant to take you away from study and knowledge of the one and only Father in heaven on high. Just my opinion mind you and I assure you judgement on my part comes out of this. Just a gentle reminder to you of what is and is not true.
The thing is, these sort of ideas where in use long before mainstream religion came along and the ones higher up the ladder realised that they could use "God" and fear to control the masses.
If you read in to a bit deeper there are certain elements that you realise "work".
You forgot fire, you'd need a gas pipepintoipe the mix too for that!
That would be an extraneous conductive part so don't forget to bond it! Or move the bed to an outbuilding without an electricity supply or a different method of protection than ads.
I do love the concept of draining all my un-wanted, negative energy ,with earth contact .
(obviously why the frugal part of me likes camping).
--Knowing "My Luck" I will drain my positive energy-
-If any science is involved--
.... If you believe - IT Will Work ...
(a proven part of the human condition) a +MA.
I'm a great believer in the placebo effect. More study needs to be done on this and the positive impact it can have on human health. In secret of course ;)
This spiritual earthing is nothing more than Pseudoscience, there is no scientific backing and even the concept is electrically wrong, does it benefit a person who believes?.. it can but for very different reasons than it is actually real, often the believer can use it to relax and also change their mood and or stress levels which is beneficial to health.
It is like a psychological placebo effect seen from a sugar pill.
I wouldn't tell her any of this though, you probably have a calm laid back happy wife, destroying ones belief system can have lasting consequences.
Does this come under ‘functional earthing’?
I would also have no idea how to calculate the appropriate csa of the cable.
...it’s amazing how intelligent people can believe in this dribble, higher beings etc.
That's what people used to say about the earth being a sphere.
I'm 99.5% sure earthing the bed will not make any difference at all, however I'm open to the tiny little chance that it might, simply because it's healthy to keep an open mind.
Oh boy! It's taken me an hour to write this as I just can't stop laughing at the opening post. :D:D:D Has anyone considered suitable labelling for the proposed bed sheet earthing arrangements into a socket outlet or are we happy with Pete's green and yellow idea?
all bollox.wear rare earth magnet bracelets on both wrists and ankles.align you bed North-South, place feet in salt water. visit Stonehenge each solstice.
Some people still do believe it’s flat. Flat earthers I believe they are called. I’m 100% sure they’re retarded.
But you are correct, I should keep an open mind but drivel like earthing yourself does not compute for me.
We had to share a cabin with one of those for a few weeks last year. Nice guy but mad as a sack of cats!
A cabin on a boat?
Nah, cabin as in portacabin. We could see water from it though - the river Mersey and could see a horizon. Couldn't make out the plumes of water rising from the waterfall at the horizon though :-(
Stuart27
Trainee
Nottingham
Spiritual Earthing..
Stuart27,
Moley,
