J
John J
So I’ve recently started my level 3 course and I’m doing electrical system designs the one with the hotel extension and pool and cafe block I’ve done question 1 but stuck on all of question 2 some guidance would be appreciated thanks.
Compare that to the farce of an exam I did last week.. 18th edition, multiple choice and you take the regs in with you..
The most difficult task was having to multiply a number by itself due to the calculators we had to use having no square function
Upvote 0
Hello :)
I'm currently on my final assessment for 2365 after spending two years at college.
I really want to complete the assessment in some design software rather than manually drawing.
I found designspark which looked as if it could do what I want but doesn't seem to like importing files.
What do people recommend? I think I would be okay with something basic I'm only literally drawing a few luminaires and to show the wiring.
Thanks in advance
Upvote 0
I used Microsoft Visio.
Drawing file is on C&G website just make sure the scaling doesn't change otherwise it will muck up your cable measurements
There are some cheap genuine/none genuine visio serial keys which you activate over the automated phone cost about £25
Edit:
A quick search found this site:
Microsoft Visio Professional 2019 Serial Key - Instant Delivery at CJS CD Keys - https://www.cjs-cdkeys.com/products/Microsoft-Visio-Professional-2019-CD-Key-(Digital-Download).html?gclid=Cj0KCQjw2IrmBRCJARIsAJZDdxCCkGiyTu0CtFt_Uk0CmzcS8TrBpkH0upQ05H9L7DJGg81VQW1YjoAaAhjSEALw_wcB
Upvote 0
Thank you that was genuinely helpful. I’ve now got the drawings in something I can edit, now it’s just a case of me figuring Visio out which I’m usually ok with.
Since you mentioned scaling where would I check that it is using the scale I need.
Many thanks
Mart
Upvote 0
So I’ve recently started my level 3 course and I’m finding hard to understand assessment 615 electrical system designs the one with the hotel extension and pool and cafe block I stuck on all of questions some guidance would be appreciated thanks.
Upvote 0
Hi all,
created this thread in hope someone could assess my work.
Task 1:
My "answer" to that:
Thank you in advance.
Upvote 0
Task A-2-a
For this part Think all that I need is just pick Light fittings with right IP rating and ENERGY EFFICIENCY.
My choice is:
Pool/IP65
Cafe/IP20
my only problem is don't know exactly if these light fittings are energy efficient?
I mean how to prove that?
Couldn't find anything like that in manufacturer specs
Upvote 0
Hi John,
I'm currently doing the same project.
The hotel rooms are like premier inns rooms. sockets either side of beds, 2 double socket on table for tv, kettle etc & socket by the sofa, heater fcu by the door & towel rail fcu outside of the bathroom.
CU in each room by the door.
when i get back home i'll convert my visio file to pdf & pm you so you can take a look.
maybe we can buddy up on this & throw ideas about?
Michael
Hi Michael
Ref 2365 615 Electrical Design Task A Question 3
Would you have copy of blank table templates used for this project please.
for example used to record Selection of protective devices and other thanks
Upvote 0
Hi Michael
Hi,
Your training provider should give you a template form?
Here's what we were given.
Upvote 0
J-Notation aka complex numbers was what I remember about the Part C.
Vector and Phasor ratios.
I don’t want to seem disrespectful but some of the lads here need to have a go. Thats the only way you learn.
Upvote 0
John J,
MrBob123,
Electrical Courses
