I've ran a coax cable through the trucking and patress box containing 230v dual gang socket. It's a satellite feed so does have 18v switching PS from the receiver. Is there anywhere in bs 7671 that says this isnt aloud?
I would say any cables run in the same containment or accessory as 230V cables should have the same insulation level as the 230V cables.
I would at least remove it from the socket back box. Maybe a separate piece of trunking up to the coax outlet.
What size cable is feeding that 13Amp twin socket?
it depends on what satalite cable it is and weather it is rated for a high enough voltage.
cables running together down trunking or through the same enclosures should ALL have a voltage rating that is higher than the voltage expected on any circuit contained in the same trunking.
below are 2 cable spec sheets for what look to be the same cable from a quick glance.
however note the difference in voltage ratings of the 2.
you need to check what the voltage rating of the cable you have used is.
and
wales
Can I run this coax cables through this patress box?
Ian1981,
