You need to be touching both ends when doing an IR test at 500 v to feel it.Theoretical.
But would not want something like this to happen in future so thats the reason for asking.
What is the theory behind testing insulation to see if it is extraneous?
Yes, but from the PoV of an innocent bystander ...You need to be touching both ends when doing an IR test at 500 v to feel it.
Why are you testing at 500V for this?
I normally apply a continuity test first, if it is above the max reading of that tester then I'd switch to the IR range but at 50V or 100V
[automerge]1597834179[/automerge]
The continuity setting of most MFT's doesnt have the range required, so the IR setting is used because it has a much higher range.
Or if your at college, attach the leads to your mates earsYou're supposed to warn anyone present before carrying out an insulation test to prevent them from receiving a shock.
Unless it's the kitchen fitter who put a screw through your cable.You're supposed to warn anyone present before carrying out an insulation test to prevent them from receiving a shock.
