Discuss New consumer unit for garage in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone,
A new small DB will be installed inside a garage for few lights and sockets. The feed will come from inside the house. Does it need to be an IP65 unit or can be the usual metal clad?
Thank you
Depends on if you think a metal clad is inappropriate for the environment. Either is fine.
Unless it is near a doorway where rain could get in (say 45 deg angle), or a known leaky roof, or where someone uses a sink/pressure washer, then I would not worry about meeting IP65.
But if it is only lights and a couple of sockets, and the house CU is already on RCD or RCBO supply, then why not just feed the sockets directly as a radial from a 20A supply and have a 3A FCU to switch the lights off that?
Unless the garage is attached to the main house. In which case the new consumer unit should probably be made of non combustible material.
Unless the garage is not part of the domestic premises
and is not meant to be used by the people who live in the house, then 421.1.201 applies, whether it's attached or not.
Fair point.
There was an article in one of the trade journals considering this. It suggested there may be a case for not applying 421.1.201 in out buildings that are not directly attached to the house.
But it depends, like so many things, on how we interpret the regulations...
Fair point.
Hard to think what that case might be apart from "we don't want to have to apply it."
I tend to come down on the side of "interpreting" things on the basis of what the actual words are and what the definitions of those words are.
Reply to New consumer unit for garage in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
