Guest viewing is limited
Are you going to give the NEW Elucian by Click® Consumer boards and wiring accessories a try?
  • Total voters
    15
  • Poll closed .
Electrical2Go
Official Sponsor
Supporter
Screenshot - 2021-07-02T104334.358.pngElucian by Click® brings to the market a comprehensive Consumer Unit and Circuit Protection range.
Covering a broad range of installations and offers a number of features and benefits that will enhance the products’ convenience, flexibility and safety properties.
Don't forget if you haven't already taken advantage of our forum discount, send us a quick message via the forum with your email address you used to create your account on the store and we'll add the 5% discount to your account for all future purchases!
Or no account yet? Sign up here and use the forum discount code:
Forum1st
Circuit breakers with my name on.... they had better be good!
OK, almost my name; that's the English spelling but mine is French.
I might try one, just for kicks.
I will stick with fusebox.
Elucian are more expensive and I found the site difficult to navigate around to see if elucian sold all the other bits you (may) need... spd, blanks, DP RCBO etc.
Thanks for the feedback we will look at making it easier to navigate the range.
No. I use SBS/LiVE units. Compact double pole RCBO's are £16 each. 10 way board with main switch and tail clamp £37.40. SPD and MCB £32. Specify your board and it arrives assembled ready to install.
I'm using lewden at £11.25+vat per type A rcbo. Yes they're full height but that really doesn't matter in a modern board, cheap, i have no reason to change unless they were cheaper and equal quality
Have you got a working link for them? I can only find a dodgy unsecure link
Terrible website !!! and NOT secure .They need to attend to these matters urgently .
very nice clean board . If they are reliable etc .Could be good idea
I believe sbs is a 1 man band shich could explain the sub standard website. Read they may be getting taken over but don't know.
Electrical2go who started this thread have a decent enough website, although I've struggled using them before with stock problems. Currently using discount-electrical.co.uk, sick of denmans and Edmondson lately with high prices and poor stock
SBS need to get someone to come up with a much better E platform. Wont even cost much . And would add value to the company
My local wholesaler tried to flog me the Click consumer units last week, opened one up to look and noticed the main switch and connections stated 1.2Nm torque MAX - that put me off
A Hager main switch is 3.6 Nm and even Wylex are about 2 Nm
100A tails tightened to 1.2 Nm - no thanks
COuld there be a valid reason for this low Nm value ? IF not well spotted .
Went to the wholesalers who had one on display and managed to take a pic of this from inside the board.
Not as bad as I thought (the warning notice relates to the cable grip), but still not great
The concerns I have about putting things like this in are the availability of parts in time to come- for example the client may want an EV charger in 5 years time, will there still be an availability of MCB's etc then?
Been burnt like that before.
Given that label says "Recommended Min Torque" what are the "Recommended Max Torque" values
Electrical2Go
Official Sponsor
Supporter
UK
Website
https://www.electrical2go.co.uk/
Other
Business Name
Electrical2go.co.uk
Are you going to give the NEW Elucian by Click® Consumer Boards and Wiring Accessories a try?
Electrical Tools and Products
Electrical2Go,
LukeD,
