- Reaction score
- 9
What cable is that? Coming from the gland?
Discuss What type of cable is this? in the UK Electrical Forum area at ElectriciansForums.net
And to think they dropped it from the nvq silibusBest cable ever made. It's pretty much bullet proof. The sheath acts as the CPC in this case.
Always called 'em silly buses for dropping it...And to think they dropped it from the nvq silibus
Never been sealed proper with a disc, by the looks........strange one if it's gone missing.The gland should have been put into a coupling, then a bush onto the trunking.... protects the cores from being bent like they are in this example.
pot is missing the seal. any idea how long this has been in service?
No idea since the building was built i guess maybe 60s?The gland should have been put into a coupling, then a bush onto the trunking.... protects the cores from being bent like they are in this example.
Whats the disc ? ?Never been sealed proper with a disc, by the looks........strange one if it's gone missing.
Nothing surprises these days, though.
Fitted to seal the compound in the pot.No idea since the building was built i guess maybe 60s?
Does it matter if its missing.
Whats the disc ? ?
Which was the driving force behind me getting a set of tools and wanting to give it agoAnd to think they dropped it from the nvq silibus
Is there a way it can be done retrospectivelyFitted to seal the compound in the pot.
Not sealed properly, the conductors are not solidly separated.
Looks like the compound's solidified but moving the cores could cause serious problems,
TBH I find it hard to believe the disc is missing. It does look 1960s which makes it imperial cable. They would be headed sleeves that pass through holes in the disc and the disc would be paxolin. That is why there are no bulges in the sleeves nor a rigidly parallel approach, and why the small area between the sleeves that is not plastered with compound looks brown rather than black.
I can see crimp marks too. One would have to be remarkably absent minded and unobservant to crimp a pot without a disc in. Especially with headed sleeves which you have to pull against the inside of the disc before crimping, which would just pull off without it.
My money is on it being correct but smothered in compound. But if the disc really is missing, no it's not OK. The slightest movement could cause a short, and it's probably not sealed so the IR will be very low.
possibly just not the black we're used to seeing - could be discoloured from heat over a number of years
I have seen it used quite a lot. I had some here but it had gone hard so I threw it out.Anybody remember the compound being green?
MICC
As others have said, it is a fantastic cable in many ways, but cost and skill level needed to use it makes it pretty rare now.Why was it done like that in old buildings?
Reply to What type of cable is this? in the UK Electrical Forum area at ElectriciansForums.net
