- Reaction score
- 67,285
looks like the plonker has used that cpc as a live,@freddo It may be my eye's, but is that brown sleeving on a bare CPC.
Sorry did not see your post until later.
What was he fixing with, a Tommy gun?had a customer call to say she had a kitchen fitter in to fit a new cupboard around the boiler and he thinks he may of hit a cable
So after chopping out two layers of tiles and some dot and dab found thisView attachment 100816
must be. otherwise how would kevin be sure of hitting them?We're they run in prescribed zones?
The two lighting cables to the left were for cabinet under lighting came out directly below the cable run and also a double socket directly below the two 2.5’s on the rightWe're they run in prescribed zones?
It seems grossly unfair that he hit almost 100% in the electrical department and 0% in the plumbing department....The two lighting cables to the left were for cabinet under lighting came out directly below the cable run and also a double socket directly below the two 2.5’s on the right
Well it looks like he was on some sort of prescription!We're they run in prescribed zones?
At least there’s a grommet in the box!Speaking of prescribed zones.
Property shows on TV. Awful.
Last nights was “Worst House On The Street” where a developer buys the worst house on the street and does it up a bit….
“Fitting these (sponsored) bath taps can add £thousands to the value….”
No… no it can’t.
So watching through as the naive developer sacks the first lot of builders… goes with more expensive ones, crashing through her budget… (wanted to spend £30k… with a little help from mommy and daddy… blew £78k on it and didn’t even touch the garden)
This scene pops up as they show the progress…
Unless there’s another socket out of shot above that chase, then vertical run isn’t in any prescribed zones.
My sister recently had B&Q re-fit her kitchen and it wasn't that cheap , the new kitchen fitted was over £8000 and this did not include any tiling or any flooring. She had to get a seperate tiler in for that. The job in its entirity cost her over £11,000Most of the time it’s a splash of paint and some “nice” light fittings…
No mention of wiring, plumbing, etc.
Next person buys something expensive that looks good, but faults will be starting… and they’ve got to fix all the hidden stuff and redecorate again.
Changing Rooms and DIY SOS are always the worst… Do all this is as little time as possible….
Paint going on freshly plastered walls… furniture going in when paint still wet!
If your budget is so limited…. B&Q kitchen, not Wren
