F
fluffy78
I have a teris lamp just like the game its made of blocks that can be changed around inside each block is 4 metal coated prongs 2 have a tiny spring that holds a removed led circuit board.
One of the prongs have broken what type of strong glue could i use to refix it into place without loosing the current.
there is only one section that has the mains power the rest pick up the current via metal plastic conductors
thanks in advance
thanks in advance
Is this item like the ones off Amazon if so they are only £20 ish pounds new.
I would have thought you need to solder rather than glue.
Can you upload a few pics.
Sure and yeah it is one of them
I don't think you will have much success at gluing them they need soldering, but you would have to be quite skilful to be able to get the chrome plated spring hot enough for the solder to take but not so hot that the plastic surrounding the tab melts.
Easily soldered with the right soldering iron etc.
fluffy78,
mainline,
