A
Adam_glover18
Hi
I'm a apprentice mainly doing industrial and commercial work what voltage tester would be best for me any advice would be great.
Adam
Purely for voltage testing, I would also say the Martindale VI13700/G Voltage Detector. Never goes faulty and so easy to use.
Apparantly Megger are also bringing out a range of different 2 pole voltage testers in January. Considering their normal standards that might be worth looking out for...
Only thing wrong with T5 is having to switch on/off etc. The T120 is a cheaper starter meter. The martindale 4 neon doesn't have continuity which I think you will find usefull.
The Fluke tester is good, you might want to check this one out from Milwaukee.
Its got a few advantages over the Fluke in that it reads up to 200a, measures temprature and has a built in torch and Volt detector.
