Darkwood
are you sure it wasn't black line and blue neutral?
most fittings can work reversed.... its just when line somehow gets connected to cpc that things get tricky... as the upside down sticker in the picture would could lead to
I thought it was originally but traced it back to find the circuits wired in red, yellow, blue singles with black neutral. All fittings had been changed to led and working with reversed polarity. Only realised when we went to test.
Had similar last week. Building from around 2000, with emergency lighting using black for neutral, red switched live and blue permanent live. Strange thing was this was all in some sort of shielded flex, so I couldn't understand why these colours were present.
That's a strange one. Was there a yellow in it or just red/black/blue?
Probably a lathe and plaster wall. I've used every screw hole available on many occasions, plus a bit of adhesive on the back.
Exactly this - only two of them were actually doing anything. This house has a mixture of L+P, L+P with plasterboard on top, and in one case L+P ceiling with OSB board and then ceiling-board which made fishing delightful fun...
Just rewired a house in which old tongue & groove timber was directly behind plasterboard on ceilings and stud walls. An absolute pleasure to work with.
8K
Darkwood,
freddo,
