- Jul 25, 2023
- 8
- 9
- 33
- United Kingdom
- Electrical Engineer (Qualified)
I am upgrading garage lighting. I have installed 12 40W batten lights (cheap Amazon variety - don’t have specs).
6A breaker in Garage consumer panel is tripping on inrush current. House consumer panel 32A breaker for garage is also tripping occasionally. Both are type B. No surprises so far.
Garage consumer panel has old style integrated wylex plug-in breakers (2-way - 32A for sockets & 6A for lighting). Cannot seem to find type-c or type-d plug-in replacements. Does anyone know where to find them - or if they even exist?
Probably need to change house consumer panel breaker to type-c? Am slightly surprised 32A breaker is tripping.
Does anyone know of any in-line delay-on module that can be wired into the lighting so I can stagger the lights on in banks. I can easily divide the lights into 3 banks that come on 1 sec after each other. I’d like to avoid having to switch/wire each bank separately.
Many thanks.
Many thanks.
