I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Is this three separate units?
Yes,the idea is to test the battery duration first unit failed ,second unit also failed and passed in third unit.To confirm it again I tested a different battery on the first two unit that failed too.What may be the cause it doesn't meet the duration?
Yes three different units of same circuit design.First ans second failed duration at 150 mins as rated duration is 180,But the third one passed.First two also failed while trying with different battery.What cause that to happen?Please
If three separate units and you have tried different batteries then the faulty units are probably draining to much current.
Are the floro or LED.
I have replaced a few hundred old units over the last few years at work and we are now all LED.
We have dramatically reduced our fail rate.
Thanks for your kind reply.They are LED and gears are quite new design .We will test the units to sort it out.Thanks again
Could also be the battery you swapped were also duff.
I have had very few LED units fail.
Out of a few hundred maybe a handful have had to be replaced
