J
jibspark
Hi all,
does anyone know where you can get the pilot drill bits for starrett arbors?
have they got to be starrett or can they be an equivalant??
i know n/e do them but thats their own range.
you get the pilot drill bits from the same supplier and if he aint got them ask him to get them
yours benji
ps why not try RS
this is a wind up ANY wholesaler will hold drill bits to fit arbors ,yes i know some are longer some have a triangular shank but come on ........
to tell you the truth ive only looked on the net and screwfix , but i guess your right, i will go dowm the wholesalers later.
i couldnt see any! i will have another look! :)
found them! :) cheers!
6mm (or is it 6.3mm?) drill bit in vice, apply grinder for 3 seconds, flat created before your very eyes. If it's too long apply grinder and crop to suit.
Does anybody sharpen their own drill bits anymore or am I the only one left?
I do ;) although sometimes with more success than other times lol remember one night at work on my own with a blunt bit and lots of stainless to drill and normally the mech engineer does it for me..i went online and self taught myself using various websites but there wasnt a lot left of it by the time I cracked it lol
i hate blunt drill bits and allways sharpen them ,6mm fits a starrett and ijust put them in and tighten the screw ,but i never use a cutter without a pilot hole so it works ok :)
i hate blunt drill bits and allways sharpen them...
Some 'tradesmen' who should know better just don't understand that a drill bit is a cutting tool NOT a grinding tool! How many times have you seen some egit with a pile of conduit boxes to drill who's whacked the drill on full speed and is practicaly standing on the drill trying to get it done as quick as poss, bit smoking red hot and a pile of blunt ones in the bottom of the saddle bag they use for a toolbox?
Once you show them a feed/speed chart from a lathe they get the idea, they slow the drill right down trying to get the longest smoothest continuous piece of swarf they can and the bit lasts ten times longer. What's more, they find it's even quicker than trying to plasma cut their way through them!!:D
i got sum from CEF the other month they where quite expensive so you can have a serch on ebay can them them on their quite cheap !
jibspark,
Green Grass,
