Reactions: Claucia 2
Are the BT lines that 90% of them use alright in your street? As that gives you loads of scope then.
I use virginmedia for work and sky for the general house devices and cameras and that does lag a lot. VM is mint though.
We're out in the sticks and only have FTC anyway, so it's kind of irrelevant. We see about 7/38 on a good day. But Sky who we're with at the moment just don't seem to have the DNS capabilities in their home routers for more than about 15 devices - as we're 30+ and constantly upstreaming camera's it's just never been that great at all!
  • Informative
Reactions: Admin
You can cut down a lot of the connected devices list surely?
I went into ours and knocked off a daughters ex boyfriend, a couple of their friends… phones we don’t have anymore…..
In fact, with that daughter in korea now, I can take off her phone and her laptop
Reactions: Admin
That's not what I meant. I'm talking about active devices which form a part of the current DHCP and routing table. It's an increasing problem in high tech households - I've just turned my head around and counted 7 from my chair, all currently talking in some form or other to the outside world. A rough total is something like 28 with just me in the house - even the washing machine is on wifi!!
Reactions: Admin
We are way too connected aren't we!
You need run all the house admin on its own router there maybe.
As for the provider consider the fact the equipment will change with a new one so may not work as well with so many devices. But get the best price in writing and go to your existing one and haggle. Always worth giving a go.
This is part of the problem. Sky doesn't talk well to anything other than it's own cheap modem/routers. I'm more than happy to spend a (sensible) amount of dosh on a commercial level system and basically have two networks running on different subnets but the bottle-neck will always be the final last-mile out to the ISP. FTP would solve this in a heartbeat as I could just go and buy a fibre modem of my choice and a decent router, alas...
I've already got two AP's running and a total of five wifi LAN's on different IP ranges, but it's the same master DHCP server in the sky box...
Reactions: BenCos18
I thought the router actively looking for certain devices that are no longer in range would slow it down… (maybe not a lot, but every little bit helps?)
I’m going to go through mine again tonight. I forgot about her Nintendo switch and her old phone that she drowned in a nightclub toilet. They can be removed.
Looking through the above posts it seems to be children that slow the Wifi/Tech down.
Reactions: Admin
I used to have similar issues, until I bought one of these
and 5 of these
you keep the sky router and turn off its wifi, connect a cable from router to Wan port on unifi and you are good to go.
Reactions: Jim_e_Jib and Admin
and 5 of these
Ha! I was looking at exactly that same Ubiquity combination earlier and emailed a local distributor for further advice. However, does the Sky box still not want to act as DHCP server and be a bottleneck?
Reactions: Admin
Good morning all!
Just back from doing an airport run and can't decide whether to go back to bed or stay up. I've been awake since 1am anyway and I have a job on later this morning. I'll probably stay up and make breakfast which is scrambled eggs and smoked salmon and a glass of Cava...got to start the day off properly!
Reactions: Admin
No, it will issue a single ip address to the dream machine.
Say 192.168.1.2
The dream machine will handle dhcp requests and for instance hand out the whole range from 192.168.0.1 to 192.168.0.255
  • Informative
Reactions: Admin
The sun is out, the sky is mainly blue and hopefully it'll be a good day. Yesterday was a pain but today looks promising. 3 x 400kV bushing oil samples, run diagnostics on a DGA analyser and prepare things for tomorrows transformer testing.
Reactions: Admin
Morning @pirate @Moley @James
Might try that router thing for sky I could get rid of the virginmedia if the house didn't thrash the sky.
But the bushing oil thing goes over this layman's head 🙄 😒 😑
But that's fine ha
I've got clouds from north to south above me now. Mind it's 3 hours after you'd said. @Lou said we are having a 16hr storm Sunday night Monday morning but we had a teaspoon of rain. So has this storm gone somewhere else then or what.
Gas boilers must be being turned on as plumbers has started it's surge in 'my boiler won't turn on' type people we get around this time of year. That's the official end of summer for me.
Say 192.168.1.2
Presumably though you have to turn off DHCP server within the sky box? And thus assign a static IP to the dream machine first?
How many simultaneous ranges can the DM provide under the same subnet? Using a class A I'd been looking for all three of 192.168, 10.x and 2.x's
ps - it won't ever issue a x.x.x.255 address as that's reserved, same as x.x.x.0
You can setup multiple network blocks, V lans, separate wifi networks running on the same access points. (If using there own access points)
DHCP can remain on for the sky router as it will give an address to the DM.
All network stuff is handled by the DM and only internet traffic is forwarded to the sky router, DHCP requests will not be forwarded through to the sky router.
Reactions: Rockingit and DPG
Thanks for this. All the AP's on POE or are there 'mains and mesh' options?
they are all POE however, if you cant get a network cable to a location, a poe injector will suffice and the AP will work in mesh mode. infact, if you have a pc near to it, then you can use the uplink port on the poe injector as a network port for the pc.
below, you can see that i have 2 wifi ssid. one a 5Ghz (fast) for most devices and a slower 2.4Ghz one as not all my smart home devices support 5Ghz
I have a single flat network but you can set up multiple networks and V lans if required
Just a quick comment to confirm that Ubiquity is excellent gear, I've used their network switches, AP points, point-to-point line of sight links and cctv cameras on a few jobs. As above, injectors are available and mesh mode works well.
Reactions: James and DPG
the only thing i would say is that their cctv cameras are expensive compared to others and their recorders will not accept feeds from other cameras.
other than that, they are my go to supplier for networking equipment now.
Gooooooooooood moooooorning viet-foruuuummmm.
Admin
Staff member
Admin
Mod
Staffordshire
Website
https://www.electriciansforums.net
Other
If other, please explain
Not an electrician at all.
Business Name
Ekthetikos
Good Morning Thread - Come say good morning, tell us what you've got on today. :)
The Electrical Exchange
Admin,
Moley,
