Hi guys I am looking for some advice, I have been tasked with the second fixing on an air to heat source pump system involving a cylinder.
I haven’t done much work like this before, there is a 4mm 3core SWA at the outdoor Samsung unit which I have terminated into a rotary isolater.
There is a Samsung control panel which I have mounted inside, I’m just looking for advice on the control wiring I will attatch a photo of the system.
It will control hot water and central heating looks to have 3 pumps, 1 x 3 port valve, 2 heating elements and a tank stat.
I also think I need to run a cable from Samsung panel to outdoor unit.
