This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Hi guys I am looking for some advice, I have been tasked with the second fixing on an air to heat source pump system involving a cylinder.
I haven’t done much work like this before, there is a 4mm 3core SWA at the outdoor Samsung unit which I have terminated into a rotary isolater.
There is a Samsung control panel which I have mounted inside, I’m just looking for advice on the control wiring I will attatch a photo of the system.
It will control hot water and central heating looks to have 3 pumps, 1 x 3 port valve, 2 heating elements and a tank stat.
I also think I need to run a cable from Samsung panel to outdoor unit.
Completely out of my remit. However, with suitably complicated looking wiring with UFH, there is usually a wiring diagram. Is there one?
As above. Somewhere there will be a set of schematics and wiring diagrams for the Samsung air source heat pump coupled to UFH (or radiators) and cylinder, and that's what's been used by the installer so far. Try googling the particular model of heat pump plus cylinder.
Here's an example of what I mean, but not knowing model numbers these won't be the right ones!
